Hello. My back door windows dont go down. And I want to know how can I fix this minor problem. Thanxs
Tuesday, December 9th, 2008 AT 1:47 PM
DON OLIVER
MEMBER
Most of the time, it is the master switch in the drivers door that fails. It can be taken apart if you have the patience and repaired but a lot easier to replace the switch. A power probe can diagnose the problem both from the rear doors and from the master switch. Good luck
