1998 Kia Sportage engine code repair p1115
EASYKIA98
Engine Performance problem
1998 Kia Sportage 4 cyl Four Wheel Drive Automatic
I need to find out how can get the code information regarding how to re- set/repair my fuel system. Thanks, ba/dv
Jul 18, 2008 at 12:22 PM
KHLOW2008
  • 41,812 POSTS
Hi easykia98,
To get info, just click the Dignostic Troubles Codes link at the right hand panel.
Repair depends on what the code tells you.
Erasing the code is easiest done with a scanner. Most codes can be erased when the battery terminal or the memory fuse is pulled.
Jul 20, 2008 at 2:54 AM
