Changing transmission fluid
159 MILES • 4 CYL • 4WD • AUTOMATIC
RBESERRA
How many quarts of transmission fluid need to be added after changing?
Mar 1, 2009 at 3:09 PM
  • 110,248 POSTS
Here is a video that shows the job being done with the fluid specs below.
https://youtu.be/5NmhYcl6cAo
Fluid Types
Fluid Type
Transmission .................... Dexron - II E or M III
Capacities
Fluid Capacity
Transmission total (Excluding cooling lines) .................... 7.08 US qts (6.7 L)
Drain and refill .................... 2.7 qts. (2.5L)
Mar 6, 2009 at 2:15 AM
CHICO23
  • 39 POSTS
If the color is like a pink color it means that the transmission has water. get and change the fluid and the transmission filter
Sep 12, 2019 at 6:55 AM (Merged)
