1998 Kia Sportage blown out sparkplug
1998 KIA SPORTAGE
168,000 MILES • 4 CYL • 4WD • MANUAL
BRYANMCORBETT
#2 sparkplug shot out. Stripped threads. Destroyed plug cover below coil. Bent plug. Second motor same problem. #4 plug last motor. What could cause this? Lower bearing? Wrist pin? Valves? As if piston rises to far and slams plug out.
Mar 21, 2009 at 3:33 AM
MERLIN2021
  • 17,250 POSTS
Is the tip that is inside the chamber getting hit? Or is it just blowing out of the hole? May have incorrect plugs, or torque isnt right. You can buy a Helicoil kit to fix the threads...and a rethreading tool for the good ones, just to make sure!
Mar 21, 2009 at 3:48 AM
BRYANMCORBETT
[quote:1686196c13="Bryanmcorbett"]Engine Mechanical problem
1998 Kia Sportage 4 cyl Four Wheel Drive Manual 168000 miles
#2 sparkplug shot out. Stripped threads. Destroyed plug cover below coil. Bent plug. Second motor same problem. #4 plug last motor. What could cause this? Lower bearing? Wrist pin? Valves? As if piston rises to far and slams plug out.[/quote:1686196c13] Tip of plug gets bent
Mar 21, 2009 at 11:32 AM
MERLIN2021
  • 17,250 POSTS
I looked for any TSB's on this and found none, could be the incorrect plugs, or the metal gasket ring that comes with some plugs is not in place? Not installed tight.
Mar 22, 2009 at 3:17 AM
