when push the clutch pedal then i shift to 1st gear, it did not move, it really on standby mode as in neutral even it was on 1st gear.
Feb 9, 2009 at 6:07 AM
DON OLIVER
MEMBER
if you haven't had any issues with the clutch slipping or grinding when trying to put in gear, look to see if the lever for the transfer case {4x4 mode} is in neutral. put it back in hi range if it is in neutral. good luck
Feb 9, 2009 at 6:13 PM
