1997 Kia Sportage clutch
198,999 MILES • 4 CYL • 4WD • MANUAL
DAN IGLESIA
when push the clutch pedal then i shift to 1st gear, it did not move, it really on standby mode as in neutral even it was on 1st gear.
Feb 8, 2009 at 10:07 PM
DON OLIVER
  • 101 POSTS
if you haven't had any issues with the clutch slipping or grinding when trying to put in gear, look to see if the lever for the transfer case {4x4 mode} is in neutral. put it back in hi range if it is in neutral. good luck
Feb 9, 2009 at 10:13 AM
