1996 Kia Sportage Can't Get Smog Test To Pass
1996 KIA SPORTAGE
BGBEVAN
  • 14 POSTS
Computer problem
1996 Kia Sportage 4 cyl Four Wheel Drive Manual
Won't pass smog test. Get several "not ready" readouts at Oregon test stations. Have tried computer reset procedure several times. Am considering replacing ECM module but not sure that will work.
Jun 13, 2009 at 1:06 AM
KHLOW2008
  • 41,814 POSTS
Hi bgbevan,
Thank you for the donation.
It should not be the fault of the ECM and replacing it might not work.
Computer needs to relearn and sometimes it does not get to ready mode because certain conditions are not met. Quite often you need to let the computer do the initial relearn correctly.
Try the following and see if it helps.
Reset ECM.
Place transmission in Neutral position.
Ensure emergency brake has been set and all accessories are turned off.
Start engine and bring to normal operating temperature.
Allow vehicle to idle in Neutral for one minute.
Turn AC on and allow to idle for 5 mins.
Initial relearn is complete, and process will be completed during normal driving.
Driving vehicle would be required for other relearn procedures to be completed. Try to drive without harsh and abrupt accelerator or braking motions.
Jun 13, 2009 at 7:48 AM
BGBEVAN
  • 14 POSTS
The first step, "bring to normal operating temperature and then wait 1 minute...." This is not a very exact timing....is it exactly 1 min? How do you know with any degree of certainty if it has reached "normal operating temperature?
Jun 22, 2009 at 2:14 PM
KHLOW2008
  • 41,814 POSTS
The best gauge of operating temperature is to wait till the temperature gauge has stabilizes itself at the normal indicating position for more than 5 minute.
From cold start , it should take about 15 to 20 minutes.
Jun 23, 2009 at 1:31 AM
RLG78
[quote:3aca8e76a2="bgbevan"]Computer problem
Won't pass smog test. Get several "not ready" readouts at Oregon test stations. Have tried computer reset procedure several times. Am considering replacing ECM module but not sure that will work.[/quote:3aca8e76a2]
I have the exact same problem. I have done the "drive cycle" several times and still get not ready. Alsost 500 miles of all types of driving and still not ready.
Any ideas?
Aug 28, 2009 at 3:46 AM
KHLOW2008
  • 41,814 POSTS
Hi rlg78,
No idea as no replies were received if the suggestions solved the problem.
Did you try those?
Aug 29, 2009 at 6:39 AM
