2007 Kia Spectra water sloshing noises in passenger firewal
19,000 MILES • 4 CYL • FWD • AUTOMATIC
TONY1TON
Do you know what is causing water sloshing noises
in the firewall area of our kia. It can't be normal &
it's not the windshield washer tank.
Thanks
Jan 3, 2009 at 5:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Your coolant resevior is probably what you are hearing.
Possible heater core? Heater core usually is located inside of dash near the firewall on passenger side of vehicle. It shouldn't be holding the coolant though, should be flowing thu freely..
Hope this helps..
Thanks for using 2carpros.com!
Jan 3, 2009 at 6:26 PM
TEGGIE
There is a drain in the dashboard that is plugged check it to see if it helps
Apr 9, 2016 at 2:36 AM
