2007 Kia Spectra Heater Control
65,000 MILES • 4 CYL • FWD • AUTOMATIC
TMEYERS1512
I have been having a problem with my car. The heat and air conditioning work (I can change the temp also), however I am not able to change the fan speed. Its always on, and on at one speed (turns off when the car is off) however, when I turn the control to the off position, it continues to blow out of all of the vents (defrost, vent & floor). I have replaced the resistor, and the controls, still isn't fixed. I am stumped! PLEASE help!
Tricia
Oct 21, 2010 at 1:14 PM
SERVICE WRITER
  • 9,123 POSTS
Two paths to take on this one.
Check the ground on the blend door actuator. Usually all HVAC actuators will be grounded together
KIA had a bad batch of control heads. The replaced head may not be a good one.
Oct 21, 2010 at 10:15 PM
TMEYERS1512
Any chance you would be able to tell me where the blend door actuator is?
And when you say the control heads, can you explain what that is?
Oct 22, 2010 at 2:12 AM
SERVICE WRITER
  • 9,123 POSTS
I am so sorry, I misread the question....
This is about fan speed..
Bear with me....
Oct 22, 2010 at 1:02 PM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_kia_2.jpg
I can email the diagram if needed. Control head, meaning the component that the switch is located on...Which I think you said you replced.
Oct 22, 2010 at 8:10 PM
