2005 Kia Spectra A/C COOLS ONLY SOMETIMES
56,000 MILES • 4 CYL • 2WD • AUTOMATIC
DONDION
RECENTLY MY A/C STOPPED COOLING AT TIMES. IT BLOWS HOT AIR SOMETIMES AND WHEN I TRY IT ANOTHER TIME IT COOLS VERY STRONG. WHAT COULD BE CAUSING THIS INCONSISTENT BEHAVIOR AND HOW SHOULD I ADVISE A MECHANIC WHAT TO CHECK OUT FIRST?
Sep 8, 2010 at 6:24 AM
  • 110,248 POSTS
When it stops working, is the compressor still cycling?
Oct 18, 2010 at 2:33 AM
DONDION
iN ANSWER TO YOUR QUESTION, THE COMPRESSOR CONTINUES TO CYCLE BUT BLOWS WARM AIR INSTEAD OF COOL AIR.
Oct 18, 2010 at 5:28 AM
  • 110,248 POSTS
If it is cycling, there is freon in the system. Have you checked the blend air door? Are the AC hoses cold?
Oct 18, 2010 at 5:53 AM
