2004 Kia Spectra Sparks plug
BRO_COKE
Engine Mechanical problem
2004 Kia Spectra 4 cyl Front Wheel Drive
Is there any special way you have to replace spark plugs on this type car.
Mar 16, 2010 at 4:37 AM
SERVICE WRITER
  • 9,123 POSTS
Disconnect negative battery terminal.
Carefully remove high-tension leads.
Use compressed air to blow any dirt or debris from around spark plug hole.
Check that spark plug fits squarely in spark plug socket and remove spark plug.
Installation
Install spark plug into cylinder head. Tightening torque: 18 - 22 lb.ft (25 - 30 N.m, 2.5 - 3.0 kg.m)
Reconnect high-tension leads.
Reconnect negative battery cable.
Mar 16, 2010 at 6:17 AM
