2004 Kia Spectra How do I replace a thermister?
80,000 MILES • 4 CYL • 2WD • MANUAL
BRANDON24
How do I gain access to the thermister on a 2004 Kia Spectra? I have removed the dash panels, unbolted the evaporator housing from the firewall, and I still can not reach or access the thermister. I can feel the two wires that go into the back of the evaporator. Is there any way to replace the thermister without evacuating the system or completely removing the unit? Will the evaporator housing need to be disassembled to remove the sensor?
May 10, 2010 at 4:40 AM
  • 110,248 POSTS
It will be at the end of the upper radiator hose on the engine under the thermostat housing. Here are pictures for the different size 4cyl engines.
https://images.2carpros.com/forum/automotive_pictures/249084_5_83.jpg
https://images.2carpros.com/forum/automotive_pictures/249084_6_13.jpg
https://images.2carpros.com/forum/automotive_pictures/249084_7_2.jpg
Let me know if this helps. Joe
Oct 18, 2010 at 5:09 AM
