2003 Kia Spectra Spark Plugs
120,000 MILES • 4 CYL • FWD • MANUAL
PATREASA
How do you get to and replace the spark plugs? Is there a picture of the location of them?
Jul 22, 2010 at 4:28 AM
  • 75,988 POSTS
CAUTION: Do not attempt any maintenance on spark plugs if engine is hot. Removal Disconnect negative battery terminal. Carefully remove high-tension leads. Use compressed air to blow any dirt or debris from around spark plug hole.
https://images.2carpros.com/forum/automotive_pictures/12900_s_2.gif
Check that spark plug fits squarely in spark plug socket and remove spark plug. Installation Install spark plug into cylinder head. Tightening torque: 18 - 22 lb.ft (25 - 30 N.m, 2.5 - 3.0 kg.m) Reconnect high-tension leads. Reconnect negative battery cable. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Jul 22, 2010 at 2:44 PM
