2003 Kia Spectra Runs poorly
2003 KIA SPECTRA
94,000 MILES • 4 CYL • FWD • MANUAL
KIACURSE!
Hi. I have 2 questions. How many mass air flow sensors are there in an 03 Kia Spectra? Also, for the past 2 spring/summer seasons, my car runs poorly. Sometimes it will skip or sputter when slowing down, the idle is rough and at other times when in 2nd, 3rd or 4th gear, the car will just shut down, or stall. I had a check engine light this time around (last summer I didnt) and it calls for a knock sensor and throttle position sensor. Both I replaced already last summer. What could be causing this? Kiacurse
Apr 29, 2008 at 11:46 AM
LEGITIMATE007
  • 5,121 POSTS
start by taking a look at your idle air control valve. thats what controls your idle when slowing down and coming to a stop
Apr 29, 2008 at 1:23 PM
KIACURSE!
ok. But what if i am not getting a code for the idle air control valve? Is there a way to check it anyway?
Apr 29, 2008 at 1:30 PM
LEGITIMATE007
  • 5,121 POSTS
you may not get a code. have it ohm tested for resistance
Apr 29, 2008 at 2:21 PM
