2003 Kia Spectra Engine swapped
40,000 MILES • 4 CYL • FWD • AUTOMATIC
BLACKOUT80601
I am working on a 2003 Spectra 1.8L and the owner wanted it swapped with 2004 Spectra 1.8L engine. The new engine is installed and it starts but, when idleing at 3300 rpm's the motor surges to 4000rpm's and shakes before it rev's up. I changed the fuel rail and injectors, tb and both sensors, checked all wiring, changed out the plugs (new but fouled out on start up), and now I am stuck.
The engine was sitting in a junk yard for a few years which is why I changed many items.
Please Help
Eric (Detroit, MI (suburb))
Jan 13, 2008 at 2:52 AM
DAVE H
  • 13,383 POSTS
did you swap the ECU's ... the setting's may be different !!
Apr 11, 2009 at 2:50 AM
