2003 Kia Spectra
128,950 MILES • 4 CYL • 2WD • AUTOMATIC
JACOBDH
My car acts like it's skipping and at times it acts like it wants to backfire it will stale at times if the ac is turned on and when u stop at a redlight it jumps and when u start off it has trouble going but once you get going it does ok, it does all these tihings worse when the ac is turned on. I have had the plugs and wires changed and 1 coil replaced it did fine and it started again so I went back to the shop and they replaced both coils and it run fine now it's started all over again, I have tried lucas treatment. It is getting to be a problem can you tell me something I need to have checked.
Jul 25, 2010 at 9:32 AM
  • 110,246 POSTS
Has the check engine light come on? Has the fuel pressure been checked? Has anyone checked the idle air control motor?
Oct 18, 2010 at 3:30 AM
