2002 Kia Spectra Door Ajar Light Stays On
2002 KIA SPECTRA
88,770 MILES • 4 CYL • FWD • AUTOMATIC
JADEINMICHIGAN
I would like to know what it will take to disconnect the Door Ajar idiot light on the dashboard. I got it narrowed down to the front, driver's side door because I can pull on the door handle and the light will turn off, but once let go, the light comes back on. I don't see a that there is a fuse that I can pull to take care of the problems. Therefore, there must be some type of wiring connection that appears to be loose. Please let me know what I can do, because the chiming noise is aggrevating to listen to
Thanks!!
May 24, 2008 at 2:14 AM
KHLOW2008
  • 41,814 POSTS
Hi jadeinmichigan,
Either the door adjustment is out due to misalignment or a worn striker rubber or the door switch cover is dislodged.
Jun 8, 2008 at 5:03 AM
