2001 Kia Spectra odometer fluctuating 5 - 10 mph
2001 KIA SPECTRA
TMAJ9447
  • 78 POSTS
Electrical problem
2001 Kia Spectra 4 cyl Two Wheel Drive Automatic 164 k miles
Details:
battery 12.7 volts
Car running battery 13.6 volts
while driving 65 mph odo jumps from 55 - 65
after about 15 minutes the check engine light came on
car appears to be running fine.
Any ideas?
May 4, 2010 at 4:10 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
My first thoughts would be a speed sensor fault, i would get a scan done to see what the set fault code is that is indicated by the check light, start here and report the code for more assistance,
mark (mhpautos)
May 4, 2010 at 7:23 PM
TMAJ9447
  • 78 POSTS
The "check engine" light is back off, the speed odom is acting normal. next day the speed odom acted up again i called KIA picked up a new speed sensor $37 bucks. Installed it speed odom working normal.
THANK YOU SO MUCH YOU GUYS RULE!!!
May 9, 2010 at 1:26 PM
  • 31,937 POSTS
Hi there,
Thats good to hear, thank you for using 2carpros, your feedback is always welcome.
mark (mhpautos)
May 9, 2010 at 3:53 PM
