2008 Kia Sorento
2008 KIA SORENTO
MINIME09
2008 Kia Sorento
how do you get the radio to come out
Mar 6, 2009 at 12:26 PM
DAVE H
  • 13,384 POSTS
AUDIO UNIT COMPONENTS REMOVAL Disconnect the negative (-) battery terminal. Remove the center fascia lower panel. after pulling it by using regular screw driver (-) Take care of fixing clips Remove the center fascia panel after loosening the screws. Avoid damaging retaining clips. Remove the connectors of center fascia panel. Remove the mounting screws then remove the center air vent Remove the mounting screws then remove the audio unitRemove the audio unit after disconnecting the audio connectors and cable. INSTALLATION Connect the audio connectors and cable to the audio unit Fasten the audio mounting screws. Reassemble the center air vent Reassemble the center fascia panel after connecting the connectors. Reassemble the center fascia lower panel. Connect the negative (-) battery terminal and then check the audio working.
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_18.png
Mar 6, 2009 at 2:01 PM
