2006 Kia Sorento fuel pump
JPRICE8812
Engine Mechanical problem
2006 Kia Sorento 6 cyl Two Wheel Drive Automatic 99xxx miles
Hi my parents own a 2006 Kia Sorento and I was wondering if you could tell me how to find the fuel pump.
Apr 2, 2010 at 11:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
fuel pump is in the fuel tank
Apr 2, 2010 at 4:49 PM
JPRICE8812
Ok, now can you tell me how to remove the fuel pump?
Apr 4, 2010 at 3:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
release the fuel system pressure, disconnect negative battery terminal from battery. remove the seat mounting bolts in rear. remove rear seat. remove service cover under center floor carpet. disconnect fuel pump connector and hoses. unfasten the bolts then pull it out to replace
Apr 4, 2010 at 8:35 AM
