2005 Kia Sorento Camshaft
2005 KIA SORENTO
42,687 MILES • 6 CYL • 2WD • AUTOMATIC
JEOSH16
Is there even a need for the external black discs on the backside of the camshaft? I have searched and searched the 2005 sorento parts lists and can't find the discs. All I can find is the front camshaft seals. [img:65666cd172]http://www.2carpros.com/forum/automotive_pictures/475544_Untitled_1.jpg[/img:65666cd172]
Feb 3, 2010 at 8:31 AM
2CARPRO JACK
  • 11,533 POSTS
Im not sure what discs you are talking about, but hey do use something similar to cap the opposing end of the head where the cam would go if the head was on the opposite side of the engine.Usually if it is in the engine, it needs to be put back in, they dont make any "extra" parts on the inside.
Feb 3, 2010 at 11:40 PM
JEOSH16
I will take a picture and post it on here. It is on the outside of the cylinder head at the aft end of the camshafts. The discs (black caps) have to removed to adjust for intake and exhaust.
Feb 4, 2010 at 12:01 AM
2CARPRO JACK
  • 11,533 POSTS
If they are external and you can access the cams, I would have to guess that you would have a huge oil leak if left off
Feb 4, 2010 at 12:13 AM
JEOSH16
Ok so I replaced the driver side cylinder head on my Sorento. Everything is still disassembled but the head is mounted. I am at the point where I will need to time the engine. Is there an easy way to go about doing the timing or do I have to take off all of the pulley assemblies to do the timing?
Feb 4, 2010 at 12:53 AM
2CARPRO JACK
  • 11,533 POSTS
You will need to time the entire engine.These timing marks should have been lined up before disassembly. I can post apic of the marks aligned, what size engine is it? is it a DOHC or SOHC engine?
Feb 4, 2010 at 3:50 AM
JEOSH16
It is a DOHC.
I didn't align all of the marks before disassembly. Does that mean it can't be timed?
Feb 4, 2010 at 10:52 AM
2CARPRO JACK
  • 11,533 POSTS
It can still be timed, but it will be difficult to get all of it lined up.When you move the crank, it can hit the valves, when you move just one cam in a head (say intake) they can make contact with the other valves (exhaust) this is why you should time the engine before disassembly.Here are the pics of how the marks should align. When the crank mark is aligned it is on TDC, you may want to back it off about 1/8 off mark, this should put the majority of the pistons down in the cylinders a little so as to HOPEFULLY not contact the valves when trying to align the marks. I would remove the cams from the head you did the gasket on as well, after the other side is tmed, you can always install the cams where they should be or at least very close.That way you dont have to worry about damaging anything on that head.If at any time you are rotating a cam and it stops, DO NOT force it, it may be making contact with something
https://images.2carpros.com/forum/automotive_pictures/1639_kia1_2.jpg
https://images.2carpros.com/forum/automotive_pictures/1639_kia2_2.jpg
Feb 4, 2010 at 11:23 PM
