2004 Kia Sorento Overheating
RDDARNER
Engine Cooling problem
2004 Kia Sorento V8 Four Wheel Drive Automatic 95k miles
This vehicle Has water in oil . Could it be just intahe manifold gasket failure or more probably head gasket?
Sep 28, 2010 at 3:33 AM
KHLOW2008
  • 41,812 POSTS
Hi RDDARNER,
Thank you for the donation.
Not likely to be manifold gasket as it is not linked to any oil passages. Most likely cause would be bad head gasket or even a cracked cylinder head.
Test would have to be carried out to determine the cause and head removal is required.
Sep 28, 2010 at 5:18 AM
