Have a leak on passenger side towards the front of the engine. When the car is running it is a drip but when the engine is off & is hot the leak pours out. The temp gauge reads normal. I have checked the coolant reservoir and there are no cracks in it. The hoses all appear to be not leaking. The leak seems to be coming from the plate that holds all of the accessory pumps and pulleys. Is there a gasket for this plate that seals water between it and the engine?
Jul 10, 2009 at 2:55 AM
