Cranks but will not start?
KWSTRING
  • 2004 KIA SORENTO
  • 6 CYL
  • 10,400 MILES
My truck showed hot on the gauge but when I pulled over and checked the engine, it was not overheating, but there was a burnt rubber kind of smell coming from the front of the engine and I also noticed a little smoke there, not the radiator but behind the belts. Then it went away, but then it would not start, it just would turn over. There was no looping while it was turning over. It turned over smoothly but would not start. Not gasoline odor like a fuel pump. Could it be the timing belt? The engine would not be gone would it?
Wednesday, September 3rd, 2008 AT 11:33 AM
Unfortunately, it sounds like you lost compression. Here is a guide that gets us started on a no start issue:
https://youtu.be/dCjmRL3p4Cs
Next here is a guide on how to do a compression test which is what we need to do next. That will tell us what the issue issue.
Let us know the results and we an go from there. Thanks
Tuesday, December 8th, 2020 AT 12:51 PM
