2004 Kia Sorento Brake Light
2004 KIA SORENTO
146,298 MILES • 6 CYL • FWD • AUTOMATIC
ANNIE_50
Brake light is staying on with an !p code what do dat mean brakes is stopping fine
Nov 3, 2010 at 10:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
brake fluid is most likely getting low, check fluid and if it is low check for leaks around the master cylinder and brake lines.
Nov 3, 2010 at 11:54 AM
ANNIE_50
[quote:4db7d2c9ce="bluelightnin6"]brake fluid is most likely getting low, check fluid and if it is low check for leaks around the master cylinder and brake lines.[/quote:4db7d2c9ce] Will check
Nov 3, 2010 at 12:20 PM
