2003 Kia Sorento tune up
114,000 MILES • 6 CYL • 2WD • AUTOMATIC
DBROWN007A
I want to tune up my Kia sorento, but don't see conventional plugs. Help...?
Thanks
Aug 2, 2009 at 5:53 AM
  • 110,248 POSTS
Does it have a plastic cover over the top of the engine? Also, can you see the spark plug wires?
Sep 1, 2009 at 2:00 PM
REXEREX
I changed my spark plugs and it was more trouble than I expected. It is a distributorless ignition system which means each plug has it's own coil mounted above it. You will have to remove the large plastic top cover and the smaller 2 covers over each bank of cylinders. Then each coil to access each plug. You will probably have to remove a metal bracket or two as well. Be careful not to stress the coils because you may break plastic. It took me 3 hours.
Jan 24, 2010 at 3:33 AM
