Vehicle hesitates and almost stalls on acceleration from when I turn from neighborhood on to main road
Jun 17, 2010 at 5:31 AM
LEGITIMATE007
✓Experienced Mechanic
have the idle air control valve checked/cleaned and clean the throttle body and plate, and you should be just fine, worse case scenario, you will need to replace the idle air control valve,(small problem)
