2003 Kia Sorento fuel pump
9,685 MILES • 6 CYL • 4WD • AUTOMATIC
JANSIE09
My vehicled stalled on me and i had to wait 3 mintues for it to start back up. I replaced the fuel
pump and the car till stalls, now when i crank it up it
wont turn over but it has power to the radio windows and lights.
Jun 26, 2010 at 10:01 AM
  • 75,988 POSTS
Do below to determine if its a fuel or spark issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 26, 2010 at 9:15 PM
