2003 Kia Sorento air bag sign on dash board
199,000 MILES • 4 CYL • 4WD • AUTOMATIC
YOR
the airbag sign in the dashboard of my car lights whenever the engine is turned on and while driving, also the brake pedals is hard to push, what seems to be the problem?
Nov 18, 2008 at 8:29 PM
  • 31,937 POSTS
Hi there,
You will have two problems, first get a scan done to determine the cause of the air bag warning light, the set fault code will tell you what is not working, and the hard brake pedal will normally be a faulty brake booster, have your mechanic check this out for you.
mark (mhpautos)
Nov 18, 2008 at 8:36 PM
