2001 Kia Sophia Non-working Speedometer
2001 KIA SEPHIA
79,889 MILES • 4 CYL • FWD • AUTOMATIC
MVIEU
My speedometer is crazy, it wobbles up and down and sometimes it actually does work right, but it is intermittently. My tripometer and odometer are part time workers as well. I have just replaced my speed sensor; prior to replacing this the speedometer was constantly at "0" and after the replacement, it jumps around. What is the problem? Is the speed sensor not working right or is there something else that I should be doing to fix the problem.
Nov 28, 2008 at 12:28 PM
Did you properly installed the VSS-could be a 2nd VSS on the speedometer assy-Double check for loose connection
Nov 28, 2008 at 12:34 PM
