2001 Kia Sephia Headlights
120,000 MILES • 4 CYL • FWD • AUTOMATIC
GEMBOBBIAN
The headlights on my car seemed to be possessed! They work and then all of sudden go out and won't come back on again until a couple days later. I had the ignition switch replaced but the problem still persists.
Jun 18, 2009 at 11:46 AM
  • 110,248 POSTS
The ignition switch isn't the problem. Chances are it is the multi switch for the high beam that is the problem or the actual headlight switch.
Do you have a seperate headlight switch, or is it part of the turn signal / highbeam... switch?
Oct 13, 2009 at 12:58 AM
