2001 Kia Sephia check engine Troubleshooting code P0441
107,000 MILES • 4 CYL • 2WD • AUTOMATIC
VABELL
I just had my kia checked to find out a reason for the check engine light coming on. I do have a problem with starting the car immediately after I fill it up with gas. The troubleshooting code is P0441 and it says it is an emission system incorrect purge flow with probable cause of 1. Faulty purge control solenoid, 2. faulty vent solenoid, or 3. Blocked vapor canister. How do I figure out which of these is the problem and fix it the cheapest. Thanks!
Jun 14, 2010 at 1:39 AM
ERNEST CLARK
  • 1,730 POSTS
This code is often just the gas filler cap is faulty. You could try replacing that for just a few dollars.
Give the computer a few drive cycles to clear the code. As for the hard start, does it do this only when you fill it with gas or anytime you cut it off and restart it???
Sep 20, 2010 at 11:05 PM
