2000 Kia Sophia Doors
117,000 MILES • 4 CYL • 2WD • MANUAL
CLIBERTY
I seen another simular problems. Mt driver door will not work either way from the inside or outside. Have tried to open by using a hanger, no luck. Freezing here in MN. Maybe the problem?
Jan 24, 2009 at 2:22 AM
DAVE H
  • 13,383 POSTS
the inner door linkages may have come off ... you will need to remove the inner door panel to locate the fault and open the door
Apr 8, 2009 at 4:26 AM
