On this the fuel pressure should be 47 PSI at the fuel rail and maximum pump output should be 92 PSI.
There is a port on the fuel rail that you can attach a pressure gauge to check the fuel pressure.
Here is a helpful video:
https://youtu.be/aITQclp7zIE
Images (Click to enlarge)
Nov 15, 2021 at 4:51 AM
