2000 Kia Sephia Don't start!
DANAG1
  • 91 POSTS
2000 Kia Sephia
I have a 2000 sephia and i drove the car to work everyday. Saturday came home from work and Sunday when I want to go shopping, the car didn't start. Turn the key to on position, all lights on board on. When I try to start no cranking, no noises at all and the lights dim to nothing. If I retry ( repet the starting process again) same thing happen over and over without having the car crank/or start.Any idea what may be wrong/broke? Thanks in advance!
Nov 1, 2010 at 8:42 AM
DAVE H
  • 13,383 POSTS
start by checking/replacing the battery
Nov 1, 2010 at 11:45 AM
DANAG1
  • 91 POSTS
[quote:ae3001eed5="Dave H"]start by checking/replacing the battery[/quote:ae3001eed5]
I thought of that but battery is fully charged. I even try to jump starting the car and still doing the same: no cranking, no start, lights diminishing to nothing.
Nov 1, 2010 at 12:25 PM
DAVE H
  • 13,383 POSTS
check if the engine will turn by hand using a wrench on crankshaft pulley .. the engine should at least attempt to crank over if being jumped ? .. check wiring to starter motor .. tap starter motor with a hammer it may be jammed up ?
Nov 1, 2010 at 12:29 PM
DANAG1
  • 91 POSTS
[quote:2e67dcaf74="Dave H"]check if the engine will turn by hand using a wrench on crankshaft pulley .. the engine should at least attempt to crank over if being jumped ? .. check wiring to starter motor .. tap starter motor with a hammer it may be jammed up ?[/quote:2e67dcaf74]
No, even when I try start jumping, the engine didn't give any sign of attempting to crank. Didn't try to turn the engine by hand yet...and I will try to hit the starter too to see if at least will give any signs of working...
Nov 1, 2010 at 1:28 PM
DAVE H
  • 13,383 POSTS
check you have power to the starter.. check the wiring is not loose damaged .. and lastly tap it a few times to try and loosen it ?
Nov 1, 2010 at 8:54 PM
