1998 Kia Sephia need to know where to put it
1998 KIA SEPHIA
FAITHFULL77
Transmission problem
1998 Kia Sephia 4 cyl Two Wheel Drive Manual
please help im trying to put in transmisson fulid in my car and i cant find where it gose where please going crazy
May 24, 2010 at 12:02 PM
  • 31,937 POSTS
Hi there, I can understand your frustration with this as the oil is checked at the speedo drive, you have to undo the cable, undo the 10mm lock bolt, with draw the drive wipe down and use it as a dip stick, the oil should be up to the top of the drive gear, see pick.
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic_144.jpg
Mark (mhpautos)
May 24, 2010 at 12:11 PM
  • 31,937 POSTS
P.S just be careful not to push the drive in to hard as you can damage the nylon gear.
Mark
May 24, 2010 at 12:12 PM
https://images.2carpros.com/forum/automotive_pictures/12900_fp_6.gif
Find the fill plug-remove the fill plug,stick your finger inside-if you can feel the gear oil you're ok-if not refill it with gear oil (80W 90) until it flows out-then plug it back in.
May 24, 2010 at 12:24 PM
