1998 Kia Sephia Engine Fan
152,000 MILES • 4 CYL • 2WD • AUTOMATIC
BLACKTOKYO2002
Enginge fan not turning on after car is good and warmed up. I have changed the thermostat and the waterpump coming to this conclusion. Fan still isnt engaging. Does anyone know where the fuse is located in the car. I got it from the auction so there wasnt a manual. Thank you for your support.
Jun 9, 2009 at 11:08 PM
  • 110,251 POSTS
Are you sure the fan is good? Try this test. Run a power supply directly from the battery to the fan motor. It should run. If it doesn't, replace the fan motor. If it does run, then you need to back track. I believe there is a fan relay under the hood in the power distrubition box. Check that. If it is good, then you may have a bad temp sending unit.
Let me know what you find. Also, in the relay box, there may be fuses for the fan. Check that out too.
Oct 13, 2009 at 1:07 AM
