1997 Kia Sophia hot water enters water reservor
JOHNNYCASH
Engine Cooling problem
1997 Kia Sophia 4 cyl Front Wheel Drive Automatic
I have...
-replaced the spark plugs with Bosch+2 prong
-replaced the spark plug cable
-changed the belts (only the visual ones)
-replaced the upper & lower radiador hoses
-serviced it for an oil change.
the car runs great (healthy feel and noise), until I have used it continueously (around 30-45 min-stuck in traffic). Then when I park after use. I hear water boiling. I open the hood and find that hot water enters the water reservor.
Im scratching my head over this one. While I wait for your ideas on what you would do, I will check for codes at Autozone.
The worried,
Johnny
Mar 2, 2009 at 11:20 AM
  • 110,246 POSTS
Hi:
It sounds like the cooling fans are not coming on. Does the car overheat when at highway speeds? Have you noticed if the fans are working?
Mar 5, 2009 at 2:47 AM
JOHNNYCASH
After your response, i checked to look and the fan wasnt working. So now thanks to you I know it needs to be replaced and in the market now to replace it. Thank you carPRO dude.
Mar 29, 2009 at 3:06 AM
  • 110,246 POSTS
I'm glad I could help. Double check the fans being inoperative by running 12 volts directly to them from the battery. If they run, it could be a relay or temp sensor. If they don't run, it's that fans.
Mar 30, 2009 at 7:02 AM
