1995 Kia Sephia coil
95,000 MILES • 4 CYL • 2WD • MANUAL
BISH172
This ca rjust died as we were driving. I replaced the coil and there is stii no spark coming out of it.There is 12 volts going to th electric plug What else could cause there to be no spark?
Apr 9, 2009 at 6:22 AM
DAVE H
  • 13,383 POSTS
DISTRIBUTOR IGNITION SYSTEM
Light Emitting Diode (LED) sensors are used to detect position of a rotating shutter wheel, located inside of distributor. As each segment of the shutter wheel passes between the LED and light source, a change in current occurs. The LED responds to the change in light by switching a transistor on or off.
This signal is used by ECM to detect the position of each cylinder or TDC of cylinder No. 1. The ECM delivers ignition signals to the ignitor to control ignition. Ignitor triggers ignition coil.
Apr 10, 2009 at 11:38 AM
