1994 Kia Sophia gasoline
1994 KIA SEPHIA
JDAUNDADOGG
Smells problem
1994 Kia Sophia
i smell gas in side my car when i start it up , i can smell it coming threw the vents . What might this be from......
Feb 13, 2009 at 7:59 PM
  • 31,937 POSTS
Hi there, i would start with having all the fuel lines & connections checked for a leak, start here.
mark (mhpautos)
Feb 13, 2009 at 8:34 PM
JDAUNDADOGG
[quote:cdaf05681b="mhpautos"]Hi there, i would start with having all the fuel lines & connections checked for a leak, start here.
mark (mhpautos)[/quote:cdaf05681b]
what else could this be from . how may other things could be causing this problem.......
Feb 13, 2009 at 8:54 PM
  • 31,937 POSTS
Hi there,
The fuel system is a full loop back to the tank, with the pump internal , and fuel lines to the filter, regulator, fuel rail & injectors and back to the pump, there will also be a carbon canister tank venting system but i am not sure if that is under the bonnet or further back in the car near the tank., check around the injectors as there are O rings seals there that can leak.
mark, (mhpautos)
Feb 13, 2009 at 9:17 PM
