2007 Kia Sedona Front Rotors
36,000 MILES • 6 CYL • FWD • AUTOMATIC
HENRY5120
  • 7 POSTS
How do you remove the front rotors on the kia sedona
Jun 26, 2009 at 7:38 AM
  • 110,248 POSTS
You need to remove the caliper. Also, if the caliper mounting bracket hinders removal, you will need to remove it too. THe rotor should come right off then. If it's tight, corrosion may be causing a problem and you may have to tap them off.
Jul 11, 2009 at 4:13 PM
