How do you remove the front rotors on the kia sedona
Jun 26, 2009 at 7:38 AM
✓Experienced Mechanic
You need to remove the caliper. Also, if the caliper mounting bracket hinders removal, you will need to remove it too. THe rotor should come right off then. If it's tight, corrosion may be causing a problem and you may have to tap them off.
