Greetings - my van has developed a massive oil leak. I traced the source to the cap of the oil filter, and I have replaced the O rings with OEM equipment. The leak continues - pouring, not dripping. Even when tightened to the appropriate specs (25 Nm), the upper O ring is forced out and the gusher begins. There are no dash warning lights indicating an oil pressure problem (yes, they are coming on at ignition). I am thinking the lube system is clogged and is causing excess pressure. Any ideas out there?
Cheers and a happy new year!
Dec 31, 2007 at 4:00 AM
