2005 Kia Sedona WASHBOARD / RIPPLEING
63,000 MILES • 6 CYL • FWD • AUTOMATIC
OKCMCKEANS
UPON ACCELERATION (FROM STANDSTILL OR PASSING) VAN DEVELOPS A WASHBOARD / RIPPLEING EFFECT. MORE SEVERE AT MID SPEEDS.
NEW TIRES AND 4 WHEEL ALINGNMENT LAST WEEK DID NOT HELP.
Nov 18, 2008 at 2:50 AM
2CARPRO JACK
  • 11,533 POSTS
so this is a suspension problem and not engine misfire? the engine accelerates ok? Did they do a full inspection of the suspension when they aligned it? im a little confused by your description..... does the steering wheel saw back and forth? is this a bouncy vibration or a shimmy like side to side?
Nov 20, 2008 at 7:35 AM
OKCMCKEANS
The steering wheel does not vibrate. The entire van does. After talking with a co worker, he thinks it's the rear motor mount. checked it out, and the motor does move fwd quite a bit when giving it gas with the brakes on. Might have drive shaft issue too. THink I'll pursue it. What say you /
Nov 20, 2008 at 10:49 AM
2CARPRO JACK
  • 11,533 POSTS
Definitly, if the mounts are out it can put cv's/ujoints in bad angles and create vibrations
Nov 20, 2008 at 11:35 PM
