2005 Kia Sedona possible battery
TTREASURECHEST
2005 Kia Sedona 6 cyl Wheel Drive Type unknown Automatic 60000 miles
when i turn the key i hear a ticking sound sometimes. Today the car did not want to turn over. It seems fine now. I dont know if it could be the battery. or maybe the starter
Feb 28, 2008 at 1:58 PM
FAIRRACING31
  • 150 POSTS
Sounds more like your battery. Be sure you have 12volts at your battery, if not have it checked out and charged up. If it wont hold 12 volts replace it. Also check to see if you have around 14volts at the battery when engine is running. If not, have your alternator checked to be sure it is working right.
Also check your battery cables and be sure your battery terminals are clean and making good contact.
Feb 29, 2008 at 3:13 PM
