2005 Kia Sedona EVAP
V_FAMILY2007
Electrical problem
2005 Kia Sedona 6 cyl Front Wheel Drive Automatic
Where is the EVAP vent valve and hose in a 05 Kia Sedona. I had it put a a reader and it is reporting a failed EVAP vent valve or vent hose.
Jul 3, 2008 at 4:27 AM
JASPERWT
  • 6 POSTS
What was the code? You can look up the troubleshooting guide on www.kiatechinfo.com which is Kia's website for repair information. The first thing you should do is make sure the gas cap is tight (three clicks). Also know that you can not run the car while refueling. Also check that the gasket on the gas cap is in good shape. This will usually solve the problem.
Jasper
Aug 5, 2008 at 8:58 AM
