2005 Kia Sedona Belt tensioner for accessory belt
85,000 MILES • 6 CYL • FWD • AUTOMATIC
JGULLIDGE
Any 14mm wrench or socket I use slips off the edges of the nut. How can I loosen this nut?
May 2, 2009 at 9:50 AM
KHLOW2008
  • 41,812 POSTS
Hi jgullidge,
Thank you for the donation.
The nut is a very low profile type normal wrenches would tend to spin out and I would recommend getting a good hexagonal 14 mm wrench to unloosen it. Care has to be taken failing which you could damage the nut and cause additional problem.
May 2, 2009 at 6:17 PM
