2004 Kia Sedona Wheel Bearing
2004 KIA SEDONA
80,000 MILES • 6 CYL • FWD • AUTOMATIC
DJQUACK12
How is a front wheel bearing changed?
Apr 10, 2010 at 1:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating The front wheel bearings are serviced with the steering knuckle as an assembly. Remove or disconnect the following: Front wheel Brake caliper and rotor Wheel speed sensor harness Hub nut Lower ball joint Strut mounting bolts Steering knuckle To install: 1.Install or connect the following: Steering knuckle Strut mounting bolts and tighten them to 88-101 ft. lbs. (119-137 Nm). Lower ball joint. Tighten the pinch bolt to 69-85 ft. lbs. (93-115 Nm). Hub nut and tighten it to 177-199 ft. lbs. (240-270 Nm). Wheel speed sensor harness Brake caliper and rotor Front wheel Check the alignment and adjust as necessary.
https://images.2carpros.com/forum/automotive_pictures/261618_1_155.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_2_103.jpg
Apr 10, 2010 at 2:56 AM
