How do you adjust the timing belt
Is the adjuster hydralic
Aug 22, 2009 at 12:49 AM
NDDUNC
✓Experienced Mechanic
its best[belive me!!!] to go buy a new adjuster,about 100.00,from the dealer.every time you change the belt,you need one. i ruined my motor &belive me 100.00 dollars is cheep. look up the timing belt diagram on this site, it will give the location of the adjuster&belt routing.good luck&best wishes
