2004 Kia Sedona jumped the car wrong
SLAURIE
Electrical problem
2004 Kia Sedona 6 cyl Two Wheel Drive Automatic
I placed the - and + on wrong when jumping my car. it smell bad inside and out. now the Battery and Brake lights are on. I did check charging system with my multimeter the volts to the battery only 12 with a new battery.
my question is, I can not find the fues for the brake or altenator. Any trouble shooting tip would help
my alt has the clip with 2 wires and on with the nut how can i test it with out braking anything else. :~(
Dec 27, 2009 at 6:51 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check the Main fuse in distribution center left side engine compartment it is 120amp. There is likely multiple electrical circuits damaged but you may have been lucky.
Let me know
Thanks for donate
Dec 27, 2009 at 7:35 AM
SLAURIE
[quote:b74f15d7e6="Docfixit"]Hi
Let me know
Thanks for donate[/quote:b74f15d7e6]
my friend came over with his meter that was the promble but my locks do not work I do not know the name of the module that controls the lock its not the keyless entry. or is it. I can not find after market part number. I do have keyless entry. I found it under the dash. could you tell me the name and were i can buy oem. kia wants 231.00
Dec 28, 2009 at 10:42 AM
DOCFIXIT
  • 18,828 POSTS
Assumed you checked door lock fuse so what controls door locks is the body control module aka ETWIS and affarid dealer only source. May try bone yaed
Is any other electrical items not working? ie. exterior lights
Dec 29, 2009 at 12:49 AM
SLAURIE
[quote:de2306cf7f="Docfixit"]Assumed you checked door lock fuse so what controls door locks is the body control module aka ETWIS and affarid dealer only source. May try bone yaed
Is any other electrical items not working? ie. exterior lights[/quote:de2306cf7f]
Did not see a door lock fuse on the online manual, or in my owners manual. any help? did not see it in the fuse box panel or under the hood. Did see the ETWIS is in the center console. I tried to find a pic. no luck
Dec 31, 2009 at 5:12 PM
DOCFIXIT
  • 18,828 POSTS
Door lock fuse in engine compart. labled BTN 3
Jan 1, 2010 at 4:52 AM
